Re: R170 SLK Supercharge Inv. Parts
One item everyone seems to be overlooking is the ECU that HAS TO be replaced at a couple grand.
There is no easy fix when it comes to installing a Blower. This is not a small block chevy.
A good harmonic balancer for the MB 3.2 V6 can run $650- $1000.
Throwing as much as 14-PSI on top of your stock injectors can, well if you can't figure that one out maybe you should go ahead and find out the hard not to mention the expensive way...
Just as I did go and take the loss on your Crossfire and trade it in on the SRT6 you will be far happier.
Plus when you get it you will find out that to increase it to well over 400 horse is less than a thousand buck. Trust me when it comes to HP there isn't ever enough.
Mike
