Old Feb 8, 2008 | 05:12 PM
  #44 (permalink)
Steve Hellums's Avatar
Steve Hellums
Default Re: 19" Racing Slicks
Originally Posted by SRTpowa
Steve, what offset are those wheels? They look like VOXX, and I only see a 40mm on discounttiredirect.com.
Sounds like a good setup as long as the offset works. I was thinking about running 18's all around with 245/40 F and 275/35 Falken Azenis RT-615, for better handling/hookup. I have had Azenis on all my cars and I love the way they perform in the curves and straight line. 17x9 with some DRs is def. the way to go for strictly drag racing, can't wait to see what you run. Good luck!
Yes they are VOXX and they are a 40mm offset.That would mean they would only sit out 5mm more than the OEM's. The 19X9.5 Stern wheels that I'm running on the rear are a 35mm (OEM) offset and I'm running a 20mm hubcentrical spacer behind them, so that would be a 55mm offset if I'm thinking right . I fitted the VOXX wheel on the rear of the car and they sat inward alot farther than the Stern's with the spacers. I wanted them to sit out a little more so when I ordered my lug bolt's I ordered a pair of 10mm hubcentrical spacers to go behind them. I'm sure a 40mm offset would work all the way around the car. My front Sten's are a 35mm offset too and I'm running a10mm hubcentrical spacer behind them and they are a 18X8.5 wheel with a 245/35/18 PS2 tire.
