Old Feb 8, 2008 | 07:37 PM
No1Piranha's Avatar
No1Piranha
Default Re: 100 Octane Fuel pump in So. Cal. SCORE!!
Combustion temperatures are too high for most cars if you run more than 96 octane. Probably ill advised to go more than 50/50 racing blended with 91. But using 50/50 every now and then shouldn't send it into melt-down mode. Unless the ECU is mapped for the higher octane though, you're not likely to feel a difference on any pump/racing blend beyond that's north of 93 or 94 octane. Most people I've know that used pump/racing blends on occassion also had multiple maps in their aftermarket or piggy-back ECUs (usually mapped the pump/racing blend at 94 octane just to leave some safety margin). Factory maps will still treat a 96 octane pump-racing blend like it's 91.
