Old Feb 9, 2008 | 10:42 PM
The_Cohort's Avatar
The_Cohort
Default Re: 1st Gear RPM Nanny
Originally Posted by apkano
I'm not sure what you mean by 4200 rpm limiter, I've only heard about the 5000 RPM limit........I'm the one who disproved the RPM limiter with the fuses pulled......youtube video that ended that thread here
http://www.youtube.com/watch?v=RwRK97G2lFM
There was also some discussion that there was a diferrence between model years, that might be what you are experiencing.
As far as entering "dyno mode"......either have your ECU hacked or find someone with the Mercedes "STAR" software and breakout box and it's possible.
I just threw this video in for fun......it's a no fuses and disabled yaw sensor run from behind a Dodge dealership.
http://www.youtube.com/watch?v=R11E_lsY2B0
I have an '05 XF. When sitting on the line and reving the engine up the limiter kicks in at about 4200 RPMs and prevents going any higher. I was wondering if there is a way to do away with this. I'll have to view your video tomorrow at Starbucks since the Academy censors YouTube from us . I thought pulling fuses 17 and 18 disabled the yaw sensor in addition to the traction control system?
