Old Feb 9, 2008 | 10:58 PM
  #120 (permalink)
downwardspiral's Avatar
downwardspiral
Default Re: Automatic Sprint Booster Group buy
Sprint Booster Power Converters - What do they do ??
All Engines Chrysler Crossfire
Do you want responsive acceleration, quicker gear changes, and overtake with ease?
This is the answer....Sprint Booster Power Converter...
Sprint Booster is a device that improves acceleration by continuously measuring and converting the digital signal providing the ECM (Electronic Control Module) with a new and altered signal.
Benefits:
At low revs, the engine responds at approximately half the time in comparison to before.
 The delay time while accelerating in 3rd and 4th gear and the engine in the mid-range, is almost zero.
 Big differences in the higher rev range.
 Improved response for downshifts and safer overtaking.
Almost all new cars come with fly by wire technology; hence do not have a traditional accelerator cable.
This new type of technology has a big draw back; it has a delayed reaction time and hence needlessly delays acceleration and engine performance.
The really great thing about this product is its simplicity; it does not touch the engine at all or the engine management system. What it does do is speed the signal up from the accelerator pedal to the engine - hence greatly improving acceleration and responsiveness!
Sprint Booster is a small and simple unit, which is very easy to install! - It is simply plugged into the back of the accelerator pedal connection and it is only possible to fit the unit one way!
“The Sprint Booster will be the “smartest” gadget you will fit to your car”.
doesnt it just trick the computer into thinking its at wot at a lower pedal position than actual wot?
