Old Feb 10, 2008 | 03:28 AM
x'ed's Avatar
x'ed
Default Re: What do I need to take a run at the drag strip?
I would also suggest that you ice down you intercooler or supercharger between runs, heat is the number 2 enemy of speed (weight is the first). I woud remove the spare tire, ahahaha ,jk. I would recomend you break boost (hold your break and press the gas and hold it there at about 2200rpm) that way you are in your torque sweet spot when you launch.
