Old Feb 10, 2008 | 03:28 PM
maxcichon's Avatar
maxcichon
Default Re: Installing Parking Lights
Originally Posted by apkano
From the service manual:
REMOVAL
1. Disconnect the negative battery cable.
2. Remove the headlamp unit.
Refer to Page 8L-103.
3. Rotate the front position lamp socket (1) counterclockwise
and pull the bulb from the socket.
INSTALLATION
1. Press the front position lamp bulb into the socket and insert
it into the headlamp unit (1), rotating clockwise to lock.
2. Install the headlamp unit.
Refer to Page 8L-104.
3. Connect the negative battery cable.
Here's the section from 8L-103 to 8L-104:
REMOVAL
2. Remove the headlamp unit upper retaining bolts (1).
3. Open the access panel in the inner fender well.
4. Remove the lower headlamp unit retaining bolts (2).
5. Lift the headlamp unit from the front fascia and disconnect
the harness connector and the front position lamp socket.
INSTALLATION
1. Install the front position lamp socket and the headlamp unit
harness connector.
2. Position the headlamp unit into the fascia area.
3. Install the upper retaining bolts (1) finger tight.
4. Install the lower retaining bolts finger tight.
5. Tighten all retaining bolts to torque specification.
6. Close the access panel in the inner fender well.
7. Connect the negative battery cable.
It's not really too tough....hope this helps!
I was able to remove the parking lamps without disassembling the housings to install leds, but if I had to do it again, I'd follow the service manual. I was unable to get a full 90 degree twist on reassembly.
When I finally do get around to taking them all the way off, can the bottom 2 screws be reconfigured to be posts intead of a true screw assembly? Or will it vibrate too much?
