Old Feb 11, 2008 | 06:50 PM
  #46 (permalink)
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: 185mm Pulley Install
Originally Posted by srt6_crossfire
so the question is who can do the custom tuning? from Brian's comment, it sounded like that Jessie tuning was not any better than the off the shelf stuff (eg. InMotion, etc.).
Given that Brian doesn't have a stock dyno, it would be good to see if he can get dyno'd on a Dynapack to compare against my dyno on my car that has SL55 setup, 178mm pullies and SI "dyno/road" tune.
I would like to make sure that I am clear to my fellow Crossfire members
I did not get a "custom tune" mine was the SI "Box tune" with just a few more dyno tweeks to correct the rich A/F ratio. If I had known I was not running lean with the 185mm pulley - I would have mailed my ECU to LET for the tune and saved a ton of $$ that I spent spinning on the Dyno.
Live and Learn - That's why I share the info - so you - my friends - can save and get the best bang for your $$
Like I said - pony up $75 and I will be glad to go to a local Dyno-Jet (not sure where there is a dyno-Pack in my area) - but unless you think my engine is junk - I don't see how you could feel the larger pulley would reduce your hp??
My only engine mods are:
Resonator removed (yea I used stainless material & proud of it)
MB SL55 Intake - (2 hour install)
LET 185mm Pulley (1 hour Install)
SI Tune
That's it!
** EDIT **
My engine has only 6,700 miles
Si Custom tune was hundreds more then what I paid - that's why I settled for what I did.
