Old Feb 12, 2008 | 07:42 AM
MMZ_TimeLord's Avatar
MMZ_TimeLord
Default Re: Pulse Voltage ???
Well, the Johnson pump works the same when replacing OEM IC Pump. The Johnson pump is a 12VDC motor. So any 12VDC should run the stock pump fine. If you are going for better cooling... change out for the Johnson pump. It's smaller and just as quiet. I had to put my hand on mine to know it was running with the engine running.
Hope that helps.
