Old Feb 12, 2008 | 08:04 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: Pulse Voltage ???
Originally Posted by MMZ_TimeLord
Well, the Johnson pump works the same when replacing OEM IC Pump. The Johnson pump is a 12VDC motor. So any 12VDC should run the stock pump fine. If you are going for better cooling... change out for the Johnson pump. It's smaller and just as quiet. I had to put my hand on mine to know it was running with the engine running.
Hope that helps.
Thanks Jody, I just have a two year degree that took me three year's to get going to school at night while working 55 to 60 hours a week. So I'm not really the sharpest knife in the drawer when it comes to complex electronic's, I make a lot better electrican . Do you think there would be any back feed problem to the control module if a guy just tapped into the hot wire down by the pump? Since it say's a "control module" there is most likely not an external relay.
