Originally Posted by cgocifer
Thanks, that looks nice!
Did you use Eibachs? Did you have to trim the bump stops? Use the stock shocks? Spring puller, or method outlined by BrianBrave in the tech area?
Thanks for the compliments. Yes I used the Eibachs. My car came with the number 3 spring pads in the rear and the number 2s in the front. I switched both front and rear pads to the number 1s (the thinest pads) for the maximum drop on the Eibachs.
I actually forgot to trim the bump stops so I will do that one day. Used the OEM shocks as well. I did spring (no pun intended) for a good Mercedes specific spring compressor. Here is a link to the set.
Spring Compressor
