Old Feb 12, 2008 | 11:08 AM
  #118 (permalink)
SLK32Germany's Avatar
SLK32Germany
Default Re: Someone on XF has a 'particularly strong' C32/SRT-6 Motor. [Dyno - SI Stage I]
Originally Posted by feets
The first item posted doesn't tell me anything except lift. It's fairly useless for a cam comparison.
The second item is a red X.
Hello,
the specs I have for the Schrick-Cams are : Intake duration 268 degrees, Exhaust duration 272 degrees, 114deg, Intake Lift 7,25MM, Exhaust Lift 7,45mm, Intake lift @tdc 0,95, Exhaust lift @tdc 1,15mm.
Maybe someone can post the specs for the OEM SRT-6 cams...
Feets, does this help for a comparison? Would be very interesting...
Kind Regards
Bruno
