Old Feb 13, 2008 | 01:37 AM
  #120 (permalink)
SLK32Germany's Avatar
SLK32Germany
Default Re: Someone on XF has a 'particularly strong' C32/SRT-6 Motor. [Dyno - SI Stage I]
Originally Posted by HDDP
No problem Feets... Take a look at the specs... and then tell me that the Schrick cams are not better than the OEM... In my original post I meant lift & duration... Even though... They will only create an additional 7-10 hp for this engine... I gave you all the information at your finger tips... Do the comparison...
http://www.turnermotorsport.com/html/index.asp
Hello HDDP,
where you have got the information from, that the Schrick-Cams create 7-10HP for this engine? On the turnermotorsport homepage I can only find camshafts for BMW... I have talked to Schrick, they also said the Schrick cams are good for 8-10HP on a OEM AMG-32 Engine. Is it possible that it could be more if you already have Pullies and Intake mods etc. ?
Kind Regards
Bruno
