Re Permissions
Hi Woody,
There must be fault somewhere - I just got the same message when I tried to reply to yours just now. However - while I'm here - did you manage to sort out your wheel security bolt prob ? Any solution you found would be good to publish here as that problem is a nightmare to fix!
ps. Im assuming you did find a technical solution to it, rather than using high explosives or a jack hammer!
