Originally Posted by msheredy
Thanks for the compliments. Yes I used the Eibachs. My car came with the number 3 spring pads in the rear and the number 2s in the front. I switched both front and rear pads to the number 1s (the thinest pads) for the maximum drop on the Eibachs.
I actually forgot to trim the bump stops so I will do that one day. Used the OEM shocks as well. I did spring (no pun intended) for a good Mercedes specific spring compressor. Here is a link to the set.
Spring Compressor
I plan on lowering my car with the same set as your car looks great!! just wanted to ask the spring compressor is a tool for instalation correct? and also what pads are you talking about?
