I don't recall a toggle switch so I hope someone else here does and can let us both know. Are you sure it is not the kick down switch on the gas pedal. I know it has one but I don't know what it looks like.
It's a small, rocker-style switch, located about 3/4 way to the top of the pedal assembly, but mounted on the bottom plate. It's just above that round black cover that you remove to access the assembly mounting nut & washer. If you want, I'll photo it. It definitely clicks, like a switch, when you alter its position.
Looking in my 2004 Service Manual (page 14-29 Vol. 2) I think it's the "Kickdown Simulator". If you have that Manual and look on page 14-27, what I may have taken as a switch are "snaps" or fastners that may hold that Simulator in place.
If so, what the "h%#l is a "kickdown Simulator"?
