Re: 185mm Pulley Install
Hi again Brian.I'm real happy with the sl55 setup, its as close as you can get to a oem look with a modification.I made two backets for each air box and fit them into the slots that were used for mounting the oem boxes. I did go with the k & n filters I made tabs on the air boxes and installed them on the front outside edge (one for each box ) then installed the windshield edge of the motor cover under the tabs and snapped it down on the original forward clip. Steve gave me a tip on using 21/2 " id reinforced hose for the drivers side tube opening next to the radiator which worked out great. I'm still trying to find out how to post pictures on the forum. As you can tell i'm not a computor wizard. This forum has a wealth of information from a lot of nice guys, i guess it can't get much better than that. ILLCYA
PS I should be ordering the boost gauge next week thanks for the information.
