Old Feb 15, 2008 | 09:54 PM
Sidez's Avatar
Sidez
Default Re: Need Your Opinions on my next Performance Mod
Originally Posted by NeverEnough
- LET Heat Exchanger and Johnson Pump (Unless you have other heat rising performance parts, live in a very hot climate, or track the car I would skip for now)
- InMotion ECU Tune (For your car this will show you tha largest gain at this point, but if u plan on Pullies, headers or camshafts at some point than do this after you do them)
- Sprint Booster (I don't understand the point of this, nor respect this mod.. skip permanatly)
- LET Intake Spacers (Same as the Heat Exchanger and Pump, Skip for now)
- NeedsWings Polished Y-Pipe (Not yet released as far as I know)
- Eibach Springs (Nice Drop for a balanced look slightly less back pain.. but i would be surprised if this acctually improved performance much or at all, either way I think it is worthy)
- Plugs and Wires (Unless you are running increased boost and temperatures, I don't see the point, UNLESS of course it is time for a change than do this)
- Modified Thermostat (Same As Heat Exhanger, Pump and Plugs and Wires, Skip for now)
Here u go, but that is just my oppnion and it comes down to the ecu tune or the springs... other than that the poster above has given the best alternative.. save for pullies...
