I have used spincaps as well for over 2 years now with no problem at all. As Steve said, I also use a little antiseize compound occasionally when checking the air. If you check the air often enough, seizing will not occur, but I like the insurance.
The most important thing in buying valve stem caps for wheels with TPMS, make sure that they have the little rubber o-ring in them to seal out moisture.
