Originally Posted by Goldwing
This is the second problem I found on my great used car deal. After delivery, I went to fill the windshield washer reservoir and the fluid just ran out. Seems the dealer neglected to change out the summer fluid and left it outside in -0o weather. Does anyone know how tough it is to replace this - is it DIY or dealer?
Actually, this may not be broken at all.
For some strange reason this system is designed so that if you overfill the windshield washer fluid reservoir the excess fluid will come out below the car. You will never see the "neck" fill up where you put in the fluid.
Does your sprayer still work? If so, and there is fluid coming out, don't panic about the reservoir being broken. They all spill over and leak out the bottom of the car when overfilled.
