Cheap Oil Change around Buffalo NY
For any of you crossfire owners living around Buffalo NY. I had my crossfire in for a check engine light at Mullane Chrysler in Lockport NY.
The service there was good and they have a crossfire tech on staff. After reading on this forum about how high the cost of an oil change is at the dealers ($100+) in most cases I was surprised to hear that Mullane does them for $80 including the filter and synthetic oil change. They also put nitrogen in my tires so that the cold here in buffalo doesn't make the tire pressure monitor go off all the time.
I don't know if that has been a problem for anyone else living in the cold climates but my warning goes off when the pressure drops due to the cold. The only solution was to over inflate the tires to keep it from going off.
The nitrogen solves that problem thank god.
Total Bill including the nitrogen, oil and filter change and the check engine light which turned out to be bad gas was $117.62!! Not too bad
