Re: Need to bleed?
No need to bleed. You might find when you are all done with all 4 corners that when you remove the cover to the master cylinder some brake fluid will overflow. The main reason for this is because when you compress the pistons on the calipers it pushes some brake fluid back through the lines to the master cylinder. In the past on other vehicles I will use a clean paper towel to absorb the excess brake fluid from the master cylinder to get it to the appropriate level. I am basing this all on brake jobs on other cars and not my Crossfire.
