Old Feb 26, 2008 | 05:20 PM
Moparrbust's Avatar
Moparrbust
Default Re: Customized Plates Suggestions
Spoiler removal is easy if you have the tools.
1) open hatch
2) remove small round cap inside grab handle area on trim panel
3) remove the single T20 torx screw under cap
4) remove trim panel by giving a nice tug on handle or around edges with a thin plastic wedge
5) remove all 4 10mm nuts recessed into hatch
6) pull spoiler off car
*There are 4 small o-rings; one per bolt hole, that sit on the spoiler side of the hatch. Make sure these o-rings are seated properly and not damaged when re-installing spoiler as to prevent water leakage.
