Very nice setup! - I really like the AEM gauge. Do you know if they offer an IAT gauge with a similar type of sending unit.
The Boost gauge I used had a remote mounted sending unit. You ran a vacuum hose to the sending unit and then the harness to the gauge head. Not quite as clean as the AEM setup.
I ended up splicing into the dash lamps so the gauge would dim with the rest of the interior lighting.
Not sure about egt but they do have a/f gauge w/ wideband setup reasonably price iirc. I was going to do one for each exhaust manifold but was like damn this is getting pricey.
Im currently working on the final mounting of the gauge next to/on the a-pillar....edit: ok i used the carbon fiber pod!!!
Did i mention the red/green aem gauge matches our factory red/green instrument panel perfectly.
