Old Feb 28, 2008 | 06:45 AM
klamathpro's Avatar
klamathpro
Default Re: Is shifting into first gear sometimes hard?
Originally Posted by RickZ
You are absolutely right, I am sure there was a TSB on it. seems like the input shaft wasn't properly lubricated at the factory.
The input shaft where the clutch throw-out-bearing slides???
Originally Posted by Goldwing
From a stop, I always go into second then slip into first. Works every time. I do find that 1-2 shift has to be precise or it doesn't slide in well. I thought that would loosen up over 26k miles but it really hasn't. So I just got used to it and adjusted to it's quirks, too.
I do the same thing with my A6.
I've been quickly learning that same trick. Just figured it out two days ago. It does seem to align the syncro when you do that. I just expected better from MB. I'm worried that we are all going to need tranny syncros replaced at 100k miles.
I also think the shifter is a tad bit sloppy, like the mounting bushings are made of soft rubber. I want to open it up and see if there are mounting bushings that can be replaced with poly or solid ones. I think this would at least help with the trim slap from quick 2nd and 4th gear changes.
