Re: Ford $80 dollar IC Pump?
uhhhh, I thought it was common knowledge that the Ford Lightning Pump will work on our cars. They are both the exact same GPM Bosch Pump. The only difference is the electrical plug(cut off and splice in Chrysler one off original pump) The hose oulet is a different size, but you just unscrew the original one off your old pump and put it on the new "FORD" one. All in all it takes about 45 minutes, including jacking the car and removing the wheel.
This has been covered at length several times before.
