Originally Posted by Sean
The latch is okay but the rubber stoppers are a crinkle-cut pattern and I can actually see the crinkle-cut embedded into the duco where they come into contact with the gutter. I figured the little rubber feet flex as the hatch flexes so for a work-around fix I put some loop adhesive Velcro where the stoppers come into contact with the gutters. Cured the issue.
Cheers
Sean.
Had the same issue with mine, the bumpers had actually wore a footprint down thru the paint to bare metal.
I used 3M Weatherstrip adhesive to glue two small strips of thin rubber to the gutter where the bumpers seat and problem fixed. The rubber was thin enough where I didn't have to jack with re-adjusting the bumpers.
Just my Dos Centavos !
