Exhaust Problem
Mar 3, 2008 | 02:53 PM
22
permalink
huudoo
Oct 2007
900
East Tn
Re: Exhaust Problem
ALSO
Oxygen Sensor Not Functioning Properly.
An oxygen sensor failure can lead to incorrect readings of exhaust gasses. The faulty sensor can cause a too rich or too lean condition. Too rich and the catalyst can meltdown. Too lean and the converter is unable to convert the hydrocarbons into safe elements and may not pass a state inspection.
Road Damage or Broken Hangers.
The catalyst inside a catalytic converter is made from a lightweight, thin-walled ceramic. It is protected by a dense insulating mat. This mat holds the catalyst in place and provides moderate protection against damage. However, rock or road debris striking the converter, or improper or broken exhaust system support can cause a Catalyst Fracture. Once the ceramic catalyst is fractured, the broken pieces become loose and rattle around and break up into smaller pieces. Flow is interrupted and backpressure in the exhaust system increases. This leads to heat build-up and loss of power. Possible causes of a catalyst fracture are road debris striking the converter, loose or broken hangers, potholes or off-road driving.
huudoo
View Public Profile
Find all posts by huudoo
