Sprint Booster
Mar 3, 2008 | 06:01 PM
permalink
Valk
Jul 2007
18,118
1,604
Aurora , ILL
Re: Sprint Booster
Quote:
JasonSmith
how exactully does it install
INSTALL
PHOTOS
compliments of PAULW
Option 1
You need to remove the throttle pedal following step below:
1. Remove the lower nut cap.
2. Remove the 10mm nut.
3. Remove the washer, a magnet helps.
4. Remove the pedal, lift the bottom pulling out and pull it out of the upper bracket.
5. Unplug the tps cable from the sensor.
6. Plug the tps cable into the
Sprint
Booster
7. Plug the
Sprint
Booster
cable into the tps sensor.
8. Reinstall the pedal assembly.
9. Go for a test drive, you WILL SMILE !!!
Option 2
Remove the kick panel on the console. This is the panel that is to the right of your foot as you sit in the car. First remove the screw on the side of the console where the vent is. After that is removed remove the second Phillips screw holding the side panel on the console in place. Remove the drivers side of the console. Now look back above the gas pedal and there is the plug. Squeeze the sides to release the locking mechanism on the plug. Unplug and insert the SB. Replug the plugs with the SB in line. Replace console side and screw and then the vent and screw and now you are done! No pedal removal or nut to drive you nuts. Simple.
Valk
View Public Profile
Send a private message to Valk
Visit Valk's homepage!
Find all posts by Valk
