Originally Posted by 1FASTC32
great write-up! i have now moved over to the Johnson CM30 pump because even the Lightning pump failed after 10,000miles...it is still a cheap fix, but the Johnson flows 3x the fluid and will not fail like the Bosch unit will...here is a link to the pump on our website...
http://www.letmotorsports.com/chy.as...6&category=all
It would seem to me that the higher rate of flow wouldn't allow the water too cool off as efficiently as a slower rate of flow. Are there any other possible issues with using this higher rate pump such as pitting internally from cavitation?
What modifications (to the pump, wiring, outlet, inlet, etc.) have to be made in order to use this pump?
Thanks
