Re: Installation of Illuminated Door Sills
First, it's not a 'relay' it's a high voltage transformer. It puts thousands of volts (low amps) into the EL Tape so it will glow properly. If you listen you can hear it make a high pitched noise.
Second, they are correct, you can't just order the part for the stock kit. If you changed your EL tape like me, you could just order another one.
Good luck!
