Old Mar 7, 2008 | 10:24 AM
eganders's Avatar
eganders
Default Re: Rear tire wear on inside
Originally Posted by almecum
Hi,
I noticed last night when I looked that the dust on the tires on the rear looked like they are only contacting on the inside half of the tire and not the whole tire. Any idea what is causing this? Pressures are set as they should be.
By factory spec they are aligned slightly inward at the top as compared to the bottom. Look at the wheels from the rear of the car to see this.. They should be touching across the entire width of the car.
If you're getting unusual wear on the inside of your tires, take it in for an alignment.
