Old Mar 7, 2008 | 10:45 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: Rear tire wear on inside
Originally Posted by almecum
Hi,
I noticed last night when I looked that the dust on the tires on the rear looked like they are only contacting on the inside half of the tire and not the whole tire. Any idea what is causing this? Pressures are set as they should be.
Sounds like the camber is out of spec to me. Bad news is camber is not adjustable. It could possiably be the tow and that is adjustable, but I would lean more to a camber problem. As your springs wear or settle it will cause your tire's to lean in a little more at the top. It's a bad design deal to have no camber adjustment on these cars front or rear. K-MAC sells adjustable camber bushings for the rear, but they are pricey, about $250.
