Old Jun 20, 2004 | 02:12 PM
David Burns's Avatar
David Burns
Default
Originally Posted by saldous
The problem is basically this. The instructions that came with them show BR/GY and BR/YL go together. So I assume that is Brown and Yellow.
Then is says RD and RD/DG go together. Assume Red goes with Red ??DG?? There are two reds in my car, one with a blue stripe and one with a yellow stripe. Which one do I connect the red from the door sills to?
Thanks.
stand by...let me go look...
BR/GY is brown with grey stripe.
BR/YL is brown with yellow stripe.
I connected the BR/GY wire from the sills to the BR/YL in the harness.
RD is red
RD/DG would be red with dark green (or grey?) stripe.
I connected the RD from the sills to the only RD wire in my harness in that area.
Note: I did NOT strip insulation off the wires in my car's harness. I used 3M crimp splices (the blue 2:1 type) that let you piggyback a new wire to an existing wire without stripping/soldering/taping.
I hope you get it figured... they're really cool!
