Old Mar 9, 2008 | 02:51 PM
pgmikes's Avatar
pgmikes
Default Re: leaking oil '05 crossfire
Originally Posted by BRappaport
PGMIKES,
I have the exact same problem. Oil leaking from small cover above the valve cover...but part of the valve cover with 2 breather hoses going in. They told me the small cover is not serviceable...and therefore the entire valve cover needs to be replaced.
Dealer is going to replace both valve covers. I had leaks on both sides.
In your case, do you know if they drained the oil and then replaced it after the new valve cover was put on? If so...did they use the same oil, or did they put brand new oil in?
Thanks
I'm not sure how it worked. But, they did not mention changing or draining the oil. I found it because I was going to change the oil. As soon as I got the car back from the dealer I changed it as planned.
