Old Mar 10, 2008 | 10:28 AM
NeverEnough's Avatar
NeverEnough
Default Re: Just got my SRT6 and problems already at 110 miles...Help
110 miles can't possible be that bad...
Don't them scare you. I've been to the track experience twice and if it only has 110 miles on it, it wasn't used much. Both times I went, I'm sure I put atleast 15 track miles on them each day. Given that they run many session per day, I would say that car had "maybe" 2 days worth of Track duty on it. That is nothing to worry about. Mine is coming up on 25,000 miles on it and I have been known to BEAT on it regularly and have had NO problems at all. It sees the Dragway at least once a month, usually twice and It's been to Summit Point and VIR several times for track days... I haven't even killed the brakes yet. I'm on my second set of tires though. What you are hearing is more than likely from LACK of use. It can only be a couple of things making that noise. Shouldn't be hard to fix. All Chrysler's have a 12 Month/12,000 mile "adjustment" warranty on wear and tear items, so it shouldn't cost you anything either.
