Originally Posted by pennstatebadboy
I'm getting new wheels for my 06 limited coupe. Is there anything I need to be concerned about with wheels that have the following measurements?
18X9 5-112 35HSM
http://www.discounttiredirect.com/di...112&vid=011477
19X9.5 5-112 35HSM
Will these fit without modifications? Is the offset ok? Will they rub? Will they interfere with the ESP system? Will the tire pressure sensors work with them? Will they look ok?
Is there anything else I should know?
Thanks!
Oh, alternatively, the 18's come in this size.
18X8 5-112 32HSM. Is that better?
A lot depends on the tire you choose to put on there.
The 18x9's will be awfully close to rubbing the upper ball joint bolt in the front with just about any tire you put on that makes use of all that width.
In the rear, you should be fine. A spacer to get closer to stock offset might be nice, but not a big deal to be without.
