Originally Posted by almecum
Hi,
I noticed last night when I looked that the dust on the tires on the rear looked like they are only contacting on the inside half of the tire and not the whole tire. Any idea what is causing this? Pressures are set as they should be.
Dust? From where? I'm not sure you can make any conclusions based on dust.
It is likely that what you're seeing is from negative camber in the rear, but doubtful that it's a problem.
If you're seeing unusual *wear*, get concerned. Even then, it's more likely to be due to toe than camber.
