Old Mar 10, 2008 | 07:24 PM
NoCones's Avatar
NoCones
Default Re: Rear tire wear on inside
IRS(independant rear suspension) cars generally have a good amount of negative camber which will cause more wear on the inside half of the tires.
as long as toe is zero (or very close), a degree or 2 of neg camber will be hardly noticeable (if at all) wear-wise.
toe it out with some negative camber...then you'll start seeing the effects
