Originally Posted by crossfirefrank
by the way if anyones interested, I changed the fog lights and all the headlights but one in about 1/2 hour. The one I didn't change was the passenger high beam (sits in front of the coolant tank). That one is going to be very hard to change. There is no room to get your hand / tool inside to pull the clip or bulb out. I tried removing the coolant tank with no luck. I removed the two nuts on the top but it would not lift off. I looked under it and it has a support that it fits into. I could not see or feel anything else holding it so I gave up.
I've removed the coolant tank, it just takes a bit of muscle. The poly "tab" fits through a rubber grommet and is kind of barbed (bigger on the end).
Remove the 2 nuts, remove (very important step!) the electrical connector from the bottom of the tank, take a deep breath and pull straight up with allota' force. It will ease out suddenly. kinda' like the shift ****!
I put a layer of o-ring lube on it when I re-installed to make it easier next time.
