Old Mar 13, 2008 | 11:06 AM
maxcichon's Avatar
maxcichon
Exclamation Re: Quick Help Needed With New Head Unit
Originally Posted by pennstatebadboy
Where is the stock amp and how do I run RCA cables to it? I just put in an aftermarket head unit using the scosche harness, and there's a lot of noise. The volume is way too sensitive as well. The lowest setting is loud. I'm pretty sure running RCAs to the amp will help. Any ideas?
The Power Amp is under the carpet in the passenger footwell. I don't think it has RCA jacks on it, just wires running to a connector block. If you read this entire thread, you'll see that SSSSly is talking about adding RCA connectors to the HEAD UNIT end of this wiring harness at the back of the head unit. Or at least to the adapter harness to preserve the integrity of the factory harness.
There have been a few threads about this very topic. Do some searches.
One more thing, in one of these threads, it was noted that the "pre-out" level of most aftermarket head units is 2.5 volts, and the xFire amp likes to see 5 volts. Hence a lower-than-expected output at the speakers.
