Old Mar 13, 2008 | 11:50 AM
jackei's Avatar
jackei
Default Re: crossfire ac recharge kit??
Originally Posted by xxfirerican
ok how do you know when its typically time to recharge it i have a 05 limited with 31000 miles on it
You never need to recharge it if there is no leaks.
You can tell the freon is low when it a/c is not cold, and you hear the a/c pump goes on and off a lot more frequenily than normal. But you will need to confirm with the gauges, it could be other reasons.
Again do keep in mind, more freon doesn't mean it gets cooler (it actually get less effective). It needs a balance (or difference actually) of high and low pressure to suck the heat out from the cabin.
NEVER NEVER NEVER overcharge the system, you will get more trouble.
