Originally Posted by cgocifer
Thanks, that is very generous of you! I'm not sure where I'd put them or if I need them. The kit I purchased uses the same system as the stock lights, system fuse too. I did purchase a supplimental relay system, but it worked terribly! My dash light stayed on and the lights flickered and went out intermittently. I've never had any problems with mine, except for the radio interference. Supposedly, there are a few kits that don't need the relays. Have you tried the system without the relays? I've heard a few have chosen not to use the relays.
Oh, I thought you meant you purchased the same kit as in this thread! Sorry!!
When you say uses the same system as the stock lights, do you have ballasts or anything? I'm a little confused and also curious!
