Old Mar 14, 2008 | 12:20 PM
cgocifer's Avatar
cgocifer
Default Re: Replaced IC pump, car still sluggish!?!
Originally Posted by arhshelby
I will check the fuse under the hood to see if it's blown, but last time I checked it, it wasn't blown. If I put my hand on the Johnson pump while the car is running, would I be able to feel it working?
How to I get the air out of the system or "Burp" the system?
You should be able to feel it running once the car is up to temperature. To prime the pump, you could release the outlet hose carefully allowing the fluid to flow out for a second. If nothing comes out, take the pick-up hose and force some coolant through it. First, just see if coolant is flowing. If it is, you have other issues.
