Do you change your oil after garaging for the winter?
Mar 14, 2008 | 02:59 PM
permalink
waldig
Feb 2008
4,508
34
VA
Re: Do you change your oil after garaging for the winter?
In my mind oil is cheap and I still change every 3000 miles and never look back. If I stored the car for a while I WOULD ALWAYS CHANGE BEFORE STORAGE TO KEEP FROM ETCHING THE BEARINGS WITH OLD ACIDS.
Sitting still adds no crud, if you want add a small heater under the oil pan with a thermal switch to cut in where you like, 40 degrees. That would be over kill. My 6 pack 440 never gets started without oil pressure first. THATs important to float the bearings after a long snooze. An oil pressure
accumulator is easy to add or as I did, make.
Waldig
waldig
View Public Profile
Send a private message to waldig
Find all posts by waldig
