Originally Posted by RIOT
Are there places in the front also?
There are 4 jack pads; that are inteded for a lift, that you can use to lift from and/or set stands under. When I did the fronts I belive I jacked each side individually by placing the jack under the pad and then put the stand under the frame rail extension or a flat spot on the engine cradle.
