Did you get this off eBay from Grille4U? Someone else?
Check your owners manual. It shows how to remove the stock lower grille by inserting the "multi-tool" or screwdriver in the rectangular slot at the outside end of the grille and just pry out. It comes out easily as it is only held in place by pressure tabs.
Hope this helps...Now as to mounting the new grille over the original, good luck, if you got it from others. The factory instructions are...how do they say, uhmm...WRONG! My grilles ship with correct instructions.
[quote=DICKBEE7631]
Originally Posted by SRT SIX
No problems with fitment. Installation is quite easy using the existing mounting points. I will get exact warranty info and post.]
I have one of your lower units but have had little time to install it. I took a look today at the directions and I see it affixes to the original plastic mesh grill. Can you elaborate please on how that original is removed? I stuck a long flat blade screwdriver into the hole at the outer end of one unit and I dont seem to be able to find whatever device is present there that I have to unattach. Do you have any sketches, details, suggestions on removing the factory mesh grill units? Any help would be appreciated. Thanks...
