Old Mar 17, 2008 | 08:08 AM
ravenous's Avatar
ravenous
Default Re: Cost to Remove Tint?
Originally Posted by robby363
You could do it yourself it's not that hard. If you start at the top corner with a razor blade scrape enough to pull it. Once you get it started you can peel most of it off in one big piece just take your time and go nice slow you might have to scrape it little as you doing it. After you get it off clean the class with adhesive remover if needed and then with a good glass cleaner. I've had to do it on a couple of cars I've owned.
I've thought of using adhesive remover if I did it myself...but I am worried I might mess up the glass - Will I?
I am also worried about scratching the glass with the razor blade....am I just being a *****?
