Thread: Wind Restrictor
Old Mar 19, 2008 | 01:29 PM
woodlands1's Avatar
woodlands1
Default Re: Wind Restrictor
Originally Posted by Hangman
Can I asked how you have it switched and where you located the switch?
Certainly, I used a pushbutton switch and it is mounted on the side (cut hole thru material for mounting). just behind the driver's seat. The installation looks clean is out of the way, so it isn't noticeable.
If you can make our Houston XFire GTG on Saturday, 29th, I will show you the set-up. If not, I can take a couple of photos so you can see. I tied the LEDs into a 12v line above the right rear wheel well.
