Old Mar 20, 2008 | 03:23 AM
apkano's Avatar
apkano
Life is random...so am I.
Default Re: What the HECK is the camber angle?
It's that high camber angle that helps us rail around corners at breakneck speeds. As you lean the car over into a corner, the weight transfers over and makes the tire sit more to the outside edge of the tire. Crossfires have a larger contact patch when they are cornering.....more contact = more grip!
To see an extreme example of this just look at a NASCAR stock car setup!
